I think its the same as a gsxr 750 if that helps. 33mm?
You can borrow mine, just come and collect it, the travel expenses might exceed the value of the puller though. I just ordered some parts from UK and freight is farkin expensive.
its on a taper. not being funny, get a screwdriver behind it so u av pressure on it, then give it a sharp tap with a hammer. it will come straight off ! put some rag behind the screwdriver so u dont damage the cases.
Derby Phoenix f400 novice champion,2006 ! For 2008, 07 cbr600rr. MRO and British junior superstock.
