  Todays Date Is: 5/19/2025 Contact Us | Home | Donations | About 400GB | Disclaimer|
 ZXR400 & ZZR400 Owner
 The Workshop - ZXR Owner
 Flywheel removal
danwillmott
Posted - 24/11/2007 :  14:26:06  Show Profile
I need to remove the flywheel from my L model, anyone know the size and type of the thread required on a flywheel puller? I can't seem to find this info in the workshop manual I've got. I've measured the thread and it seems to be somewhere between 28 and 30mm.
Cheers - Dan
Duane
Posted - 24/11/2007 :  19:42:40  Show Profile
Not sure what you measured it with, i think its an odd size, like 33 or something, from memory it is the same flywheel puller as a GSXR 750T.
Just found it, in workshop manual, electrical section, tools required.
M33 x 1.5
The older I get the Faster I was!
danwillmott
Posted - 25/11/2007 :  09:10:07  Show Profile
Cheers Duane, I measured it again and yup 33mm would be right.
Now, to find a 33m puller ...
mick41zxr
Posted - 25/11/2007 :  22:18:09  Show Profile
Make one with a 33mm nut from industrial supplies, weld a 12 mm nut to one side. wind the 33mm nut to flywheel by hand then hold it with a spanner, then use a 12mm bolt & rattle gun drive the flywheel off the crank.
Regards,
MB
danwillmott
Posted - 26/11/2007 :  19:22:02  Show Profile
I was already thinking along the line of buying a 33mm nut and trying to fashion something - but I don't have access to welding gear.
I do have a claw type puller, so I'm gonna wind on the nut (once obtained) and put the claw puller on the edge of the nut and wind it in onto the end of the crank - ideally done with a nut with a big flange (always like to drop the word flange into conversation). Not sure if that's gonna work... but it's all I have to go on at the moment.
ratbga56
Posted - 26/11/2007 :  23:22:52  Show Profile
i used a puller but that didnt work, so i used the hydraulic one i have at work that got the bloody thing off lol
