  Todays Date Is: 5/25/2025 Contact Us | Home | Donations | About 400GB | Disclaimer|
 Headlight stopped working
Posted - 12/09/2007 :  19:52:15  Show Profile
My headlight stopped working today. It doesn't come on with the ignition, and main beam doesn't work either, but the 'pass' switch makes it work. Checked and changed the bulb, checked all the fuses and it still doesn't work. Short of going through all the wiring are there any other suggestions????? My heated grips are wired in to the headlight but are not plugged in at the moment and haven't been for ages so Im assuming that they shouldn't be affecting it......
heppie
Posted - 12/09/2007 :  20:03:39  Show Profile
checked the contacts?
Posted - 12/09/2007 :  21:16:12  Show Profile
Yes, all been cleaned....
Just realised, haven't checked the relay in the starter switch, common problem and its where i'll start at sunrise tomorrow!
Edited by - superfourben on 12/09/2007 22:24:25
Posted - 13/09/2007 :  01:13:24  Show Profile
Obvious start point is the RH bar switchgear if it works off the pass switch on the left. Try it again with high beam selected just to be sure its not just the low beam filament in the bulb
Posted - 13/09/2007 :  08:46:07  Show Profile
Yeah the bulb was fine, turned out it was the RH switchgear. The connection for the relay that cuts the light out had come away so I re-soldered it and all is fine......
Edited by - superfourben on 13/09/2007 08:46:20
