  Todays Date Is: 5/17/2025 Contact Us | Home | Donations | About 400GB | Disclaimer|
 VFR & RVF Owners
 The Workshop
 Fuel vacum, has it been done already?
Goodwin
Posted - 30/08/2007 :  09:33:18  Show Profile  Visit Goodwin's Homepage
Hello, as reported on another thread my bikes got covered by water in the recent floods, the VFR has been taken back to the bones and put back again, its turning over and getting a spark, I can get the bike to start by dropping some petrol into the carbs but wont start from the tank.
Ive read that the vacum could be the problem, the pipe from the tank to the bottom right carb was missing, I asked my brother who previously owned the bike and he said it never had a pipe on it! making me think that the conversion has already been done.
The tap itself has the three pipes, one for the petrol (thick pipe) and two pointing down, not one in the same direction as the fuel pipe as in this image
The petrol flows out of the tank easy when the tap is turned on, but think its not getting through.
Any suggestions? do you think the tap conversion has been done?
nakes
South Africa
Posted - 30/08/2007 :  10:09:58  Show Profile  Visit nakes's Homepage
If the fuel flows out the tap freely when the tap is open then I think the fuel tap mod had been done...
http://www.hondarvf.com - A community driven workshop guide...
Cam
Posted - 30/08/2007 :  13:40:52  Show Profile  Visit Cam's Homepage
Why not just open it up and look? Tis only four screws...
http://www.localbikers.org.uk: Creating communites for the bikers of the UK.
Tanuki
Bike washed twice a year
Posted - 30/08/2007 :  13:50:21  Show Profile
quote:
and you would be right.
Ha ha ha, oh my God! I almost didn't do it, I almost didn't do it! I thought, is this in bad taste? But you know what, I went for it. I went for it and I'm so glad I did! Ooooh, worth it, totally worth it.
Goodwin
Posted - 30/08/2007 :  18:53:12  Show Profile  Visit Goodwin's Homepage
Just wanted confirmation, will have to take a look to see why its not getting through, any suggestions based on it being recently covered in water?
nakes
South Africa
Posted - 30/08/2007 :  20:26:12  Show Profile  Visit nakes's Homepage
quote:
A small fish stuck in the fuel lines.... lol
Have you opened the carbs up? Maybe the floats are stuck or something?... basically check that everything between the fuel tap and carbs is clear and that the carbs are perfect... nothing stuck or clogged with gunk...
katana
Posted - 31/08/2007 :  14:50:30  Show Profile
Why would you do the mod?
Tanuki
Posted - 03/09/2007 :  10:45:10  Show Profile
the mod was for the HRC race bikes because when running at WOT for long periods the bikes wouls suffer from fuel starvation...this wont happen on the road so is a pointless mod IMO.
a few people on here have has big problems with the cylinders filling with fuel when the bike has been stood for a while...
alivee4
Posted - 04/09/2007 :  04:31:22  Show Profile
If you're running big jets (open carb set-up) it's absolutely necessary. The vaccuum just can't keep up the fuel supply. But as Monkey says, a few have had major probs with it, so only use it if you have to and preferably with a dry break for insurance. It's very easy (and potentially expensive) to forget to turn the tap to 'off'.
NC30 track bike on a carbon fibre diet
shipleymanx
Posted - 07/09/2007 :  12:39:11  Show Profile
As i am new to 400, what do you do to the tap. I presume that without this mod the fuel was drawn through by vacuum, is this correct
vfrman
Moderator
USA
Posted - 07/09/2007 :  16:31:45  Show Profile  Visit vfrman's Homepage
There is a little diaphram inside the pet*Censored* that is closed when the engine isn't running. When you start the motor, a vacuum is created on one side of the diaphram, pulling it away from its seat and allowing fuel to flow.
91 VFR400R
Hill AFB, Utah
USA
kenny629
Posted - 07/09/2007 :  20:31:38  Show Profile
going to do mine at the weekend, wouldnt start earlier today as the fuel tap was playing up, far better without having to rely on the vacuum, just have to remember to turn the fuel tap off when leaving the bike sitting for a while
kenny
bravery is being the only one who knows your afraid
JonRA23
Posted - 07/09/2007 :  21:12:44  Show Profile
Hi Goodwin
If the carbies went underwater you will have to strip them down and clean any water out of them to get it to run.
You dont have to pull them appart completely just the vacuum tops and slides out, float bowls off, jets and needles and seats out. Then give them a blow out with compressed air and re-assemble.
The float bowls have o orings on them so you won't need any gaskets or the like, pay to check the float level while you have them appart.
regards
jon
