irish tommy
30 Posts |
Posted - 23/03/2008 : 17:01:31
hey, the throttle cable snapped today on the super4, has anyone replaced a throttle cable before, is it difficult, any advice,thanx. |
1009 Posts |
Posted - 23/03/2008 : 18:41:27
Not too difficult but a bit fiddly. Undo 2 screws holding switchgear Undo nuts on throttle cables which secures them to switchgear Slacken cables, remove bust one from throttle assembly Remove tank Unthread cable from mounting clip Remove from carbs
Installation is the reverse of removal!! You may wish to oil new cable before it goes in, however new cables generally have a coating so should be fine for a while. |
I've got 4 words for you sonny: ... |
irish tommy
30 Posts |
Posted - 23/03/2008 : 18:55:49
thanx tektrog, i was checking on the wemoto website for a new one and they have two different throttle cables, a pull cable and push cable i know its probably a stupid question but how do i tell which one to get,thanx |
1009 Posts |
Posted - 23/03/2008 : 20:50:01
Correct.
It'll be the same as the one you take off that's snapped.
Think about how the throttle operates and I'm sure you'll work it out. |
Posted - 23/03/2008 : 22:27:26
Incidentally, this is far more trouble than it should be on a CB. I had the cables off the diversion for a check/lube, and it's a separate throttle housing on the handle bar - two screws and the cables fall out, piece of cake to put it all back together.
I would get both cables, especially if you are buying a pattern part. But as above, you will soon work out if you twist the grip while looking at the carbs and see which cables does what. |
