robs321
45 Posts |
Posted - 13/02/2008 : 07:17:57
my better halfs 96 super four has a knock when the front breaks are applied. If its not the head stock bearings any one have any ideas where else to look?
cheers Robs |
Drewski
85 Posts |
Posted - 13/02/2008 : 10:30:41
Hhmmmm... head bearings would be the first place to look I guess but if you're sure it's not them, maybe the caliper, fork bushes, damper rod bolt come loose? wheel bearings? If possible, get someone to bounce the front up and down while you listen to the forks with a screwdriver acting like a stethoscope. |
Born To Ride, Ride To Born! |
1009 Posts |
Posted - 13/02/2008 : 23:22:24
Pulsing through the lever? Maybe warped caliper. |
I've got 4 words for you sonny: ... |
robs321
45 Posts |
Posted - 16/02/2008 : 18:00:42
no just one knock! as the brakes are applied
cheers Robs |
Posted - 16/02/2008 : 18:27:14
fork bushes most likely. ask yourself if you can really be bothered to take the forks apart for it? i suggest leave it til the seals next pop, then do a rebuild with all 4 bushes, oil and all 4 seals. |
