gsxr400 racer
USA
2630 Posts |
Posted - 21/12/2007 : 23:41:54
quote: Originally posted by cantona
ive been testing everything because it wont start at the fusebox there doesnt seem to be any power to fuse 3 anyone know what this one does Isn't there a funny push button fuse on the 76 under the battery box STRIPES correct me if im wrong but doesn't it control main power far fetch but i have also seen where the kick stand switch is not pushed in far enough to make contact and you will have power and no start ive also see a kick stand with a weak spring and going down the road the bike would cut in and out like the coil power wires where loose. lol also right hand side indicators back one comes on but doesn't flash front doesn't come on at all bulbs are good and there's power to the bulb holder could it be relay even if left hand side works fine
I would have to say that the above is a loose wire. |
Supplier of the cheapest 442cc big bore piston kit for gsxr400 73,76, bandit 400, and other Suzuki's, carb kits(o-rings), race tensioners, shim kits for 76( for adjusting valves) as well email me! cheers |
