rover220
116 Posts |
Posted - 13/12/2007 : 16:13:03
dont know if this is a problem or not but at idle and in neutral, if i open the throttle fully, it gets to about 12000 then its like it misfires and the revs drop even if i keep throttle open. the neutral light also blinks in time with the "misfire"
is it supposed to do this? i wont know if it does it on the orad till the weekend but would appreciate any advice on this.
btw, i know you shouldnt rev it like that, i was doing it as part of the bleeding process.
cheers
mike
zxr400 L4 import, micron race system, #105 main jets, k&n filter, rsd crash mushrooms etc etc |
jameszxr
12 Posts |
Posted - 13/12/2007 : 19:01:58
sounds like the carbs need balancing to me |
techie
New Zealand
919 Posts |
Posted - 13/12/2007 : 22:15:28
Quite often whilst in neutral and you snap the throttle open, it will hit the rev limiter before the tacho needle ctaches up and hence appears to mis at a lower rpm. Tough on the engine, but gradually increase the rpm rather than a quick transition into a wide open throttle. You will probably find it'll rev cleanly. Or take it out on the open road and test it under load to redline and make sure it does not cut out befor it's meant to. |
Lose weight and go faster. |
zimm
1378 Posts |
Posted - 14/12/2007 : 12:33:08
what techie said :) |
sooo.. who wants to lend me 6k then ? |
rover220
116 Posts |
Posted - 14/12/2007 : 15:13:33
quote: Originally posted by zimm
what techie said :)
nice one, i guessed it was something like this but i dont know enough about them yet to decide whats what.
will have to get it out on th eorad asap to check but i doubt its a problem.
cheers techie and ross |
