505 Posts |
Posted - 09/10/2007 : 00:01:00
Every now and then my brakes go tight, ie as if the span adjuster has been set to furthest span, so if i barely pull the lever the brakes are suddenly there. This then remedies itself if I push the brake lever away from the bike with the back of my hand. Brakes are then back to normal. Though at first it was dirt in the span adjuster, then had brakes bled both to no avail... could it be master cylinder sticking????? |
Good times! |
Posted - 09/10/2007 : 10:28:19
more likely seized/ing sliding pin, then caliper slave piston, in that order. If you don't look into it soon you could end up with a seized caliper and that means a warped disc. Get your hands dirty, have a look. |
heppie
80 Posts |
Posted - 09/10/2007 : 12:23:57
mines starting to do the same. Oh well it needs new pads anyways... |
505 Posts |
Posted - 09/10/2007 : 17:40:28
I've got a braided brake line kit to put on so looks like i'll be adding this on to that list of 'to do' jobs as well |
Good times! |
505 Posts |
Posted - 14/10/2007 : 11:35:39
Removed brake lever and cleaned a couple of years of black gunk from around the sliding pin, rubber dust seal and the lever and it seems to have solved it  |
Good times! |
