Yorkie
62 Posts |
Posted - 11/09/2007 : 17:32:33
this morning my bike started on 2 or 3 cylinders so i let it warm up and sure enough they all stated to fire, but now when i start it up there is a really loud ticking noise on the right hand side that dies down after a few seconds, so you can only just about hear it, now it has ticked for a while (had posted previous topic) i was just wondering what could be up and where i could get the parts needed to fix it |
Posted - 11/09/2007 : 19:26:20
checked the oil lately? |
Yorkie
62 Posts |
Posted - 11/09/2007 : 19:48:42
replaced oil only 2k miles ago, but i am going to change this weekend as well as the filter
you reckon i will cause any damage if i continue to ride it until i get the parts ?
i will continue to let it warm up before use |
Edited by - Yorkie on 11/09/2007 19:55:37 |
heppie
80 Posts |
Posted - 11/09/2007 : 21:23:34
guessing its a tappet that is slightly slack and it makes quite a bit of noise until the oil reaches it |
Posted - 11/09/2007 : 23:14:36
Could be an exhaust gasket? |
hondaneil
96 Posts |
Posted - 12/09/2007 : 17:05:16
sounds like it is low on oil. With the bike on its side stand the oil slips to the left hand side of the engine. It takes a few seconds for the oil to pump around to the dryer parts. You could check the oil and top it up before you get the new filter etc, just to see you through. I wouldn't worry about the prospects of it doing any damage, these engines are pretty robust. |
Yorkie
62 Posts |
Posted - 12/09/2007 : 18:57:59
just wondering what sort of oil i should be using i believe 10w40 semi syn is in there at the moment just wondering if i should perhaps go fully synthetic, bike has done roughly 23000 miles |
505 Posts |
Posted - 12/09/2007 : 19:55:15
I use Castrol synthetic 10W 40. |
Good times! |
Dick Steele
Philippines
215 Posts |
Posted - 18/09/2007 : 11:09:15
Hearing the "ticking" noise at initial startup is OK. If the ticking noise doesnt disappear after more than 3-5 seconds, then its something else. More often than not, primary reason for the ticking sound is when the oil is still all the way down the pan. Thats when the oilpump is briging it all back up to circulate. As long as the noise is gone after a few clicks is nothing to worry about in my books... |
"Keep ridin to where the sun dont shine"
(+63917-452-9190) |
Yorkie
62 Posts |
Posted - 26/09/2007 : 21:00:37
Right just to let you lot know, a service fixed this, there is now no ticking noise to be heard at all
changed both filters, and put in 5w/40 synthetic oil, also changed the exhaust to a standard one so my old one is up for grabs email me for more info if you are interested :D |
Edited by - Yorkie on 26/09/2007 21:05:59 |
Seeby400
590 Posts |
Posted - 27/09/2007 : 07:40:53
Sounds like it was prob the exhaust change that made it go away.....perhaps the old one blowing at the manifold....i had a loose exhaust stud on my S4 thats made the bike tick tick tick all the time until i tightened it. Seeby |
Keep it gutter....keep it grimey................one |
