Henniebrandweer
South Africa
215 Posts |
Posted - 10/09/2007 : 05:43:06
Hi Guys , as you all seen in my other post, i redone the bike, but now it gives me only 150KM before i have to switch over to reserve? could this be right? or is it not set right?
Thanx |
I put Wet stuff on the Red stuff!!! |
Johnnie5
246 Posts |
Posted - 10/09/2007 : 07:27:32
depends on how you ride it
i put a 1/2 system on my bike with short gearing and used to ride it 9K+ RPM all the time and 150 to reserve was pretty normal |
Henniebrandweer
South Africa
215 Posts |
Posted - 10/09/2007 : 08:05:47
ok?! so that gives u about 15Km's per litre? |
Alzazor
South Africa
184 Posts |
Posted - 10/09/2007 : 09:11:42
It all depends om how you ride hennie, I get 215KM on a full tank if I ride rustig. |
Know God in everyting,even your bike!May God speed! 98RVF400NC35 - Still original.(Not for long...) |
nakes
South Africa
563 Posts |
Posted - 10/09/2007 : 10:16:20
I get about 170-180 to reserve |
http://www.hondarvf.com - A community driven workshop guide... |
Henniebrandweer
South Africa
215 Posts |
Posted - 10/09/2007 : 12:02:54
just found out that the pipe comming from the tap to there where it splits in 2 for the carbs was leaking a bit, maybe thats why, ill see what it does now, thanx guys, but does the jets that i put in make a big difference? 117.5 front and 120 rear? |
Cammo
3023 Posts |
Posted - 10/09/2007 : 12:23:58
The jets will make bugger all difference.
Do you tilt the bike vertical when filling with fuel? You can easily squeeze an extra litre or more in when doing that. It mostly comes down to how you ride it. |
I DUG the underground! |
viper_biker
Administrator
7563 Posts |
Posted - 10/09/2007 : 12:35:40
I can do a tank and a bit on a track day and thats about 8/9 laps, 1.5miles per lap and do about 5 sessions, you do the math. |
Social worker: "Glen honey, I got a question for you. What do you do for a living? Quagmire: "I got a question for you. Why are you still here?" |
Hannes
South Africa
135 Posts |
Posted - 10/09/2007 : 12:41:01
Hennie I rode to Suldana last satudey with a buddy. He has a ZX9RR and we were going between 160 to 200 km/h all the way. And at 130km I had to switch over to reserve. Ended up with 150km at garage on the way back and had to fill up with 12.5 liters.
Last week-end I had a major service done. Carbs are ballanced valve clearance done, new tyres, etc. I also noticed that since removing my speed limiter I use much more fuel than previously. So if you are heavy on the throttle you will chow fuel. I must still learn how to take it easy on the long rode!
Just a couple of weeks before that I had a much slower run with another friend who has a NC30 as well. And then the consumption was much less (200km on tank).
At the sounds of it your bike is going well now? |
I live one quatermile at a time! |
Henniebrandweer
South Africa
215 Posts |
Posted - 10/09/2007 : 12:59:28
Yes i do tilt it vertically, but i think its the leak that made it look so heavy, we'll just see nou, i fixed the leak....... i hope
but Cammo, what do u think about the jets that ive got in now, do u think its gonna make more of a difference if i try even bigger ones? and what size? |
Henniebrandweer
South Africa
215 Posts |
Posted - 10/09/2007 : 13:05:54
well i dont think its going like its supposed to, because, when i push it hard on the open road, it seems like it just reaches 190km/h so even with the speed limiter removed i dont think its going to go much past that, and it doesnt pull as good as my old NC30 did, with pull away at about 9000rpm it jurks a bit up to about 12 13 then pulls through but im sure not as it should, what does this foam filter do?? too much air or what? and i dont even have an old airfilter to test the difference!!! this sucks! someone please give me miracle advice |
Alzazor
South Africa
184 Posts |
Posted - 10/09/2007 : 16:56:44
Get ure bike on a dyno |
Cammo
3023 Posts |
Posted - 10/09/2007 : 20:44:17
A standard filter will fix it!! |
Henniebrandweer
South Africa
215 Posts |
Posted - 10/09/2007 : 21:15:36
Ok, if u say so, then I'm buying a standard filter as soon as I have moohla, lol, u have all the way only given me good advice Cammo, thanx, so should I buy an original honda one, or can I get a generic one? coz its grey imports here, I don't think I'm gonna get a original one? |
Cammo
3023 Posts |
Posted - 10/09/2007 : 21:33:47
Original only hennie, if I had a spare it would be sent to you already!
(actually might have a good used one you can have for postage only, I'll let you know).
There seems to be enough nc30's in SA that someone will be supplying genuine air filters. I don't know if there are any generic ones for the '30. |
Edited by - Cammo on 10/09/2007 21:37:04 |
nakes
South Africa
563 Posts |
Posted - 11/09/2007 : 00:08:36
Hennie you will find an original here in SA... I bought an original Honda filter for my RVF at Suzuki South here in Cape Town. I'm sure you'll find one in your part of SA... try Mitaka or Racebox. I'm pretty sure Gerhard at Racebox can supply it.
In fact Suzuki South are pretty good with supplying parts for grey bikes but not sure they'll post it to you... |
Henniebrandweer
South Africa
215 Posts |
Posted - 11/09/2007 : 15:56:00
THANX GUYS, WILL PHONE A COUPLE OF PLACES AND LET U KNOW WHAT I FIND OUT, HOW MUCK DID U PAY FOR URE'S NAKES? |
nakes
South Africa
563 Posts |
Posted - 11/09/2007 : 18:02:49
I paid around R350(about 24pounds) less a 10% discount. |
Henniebrandweer
South Africa
215 Posts |
Posted - 11/09/2007 : 19:01:46
ouch! guess I have to save then, lol |
