gixxer
108 Posts |
Posted - 02/06/2003 : 19:51:46
Fitting braided hoses recently i had to remove the tail unit to get at the reservoir for the rear master cylinder, it was the first time i had it off this bike. I noticed the overflow bottle was empty, is this normal or should there be a bit in it, i cant see any markings on the side of it! the temperature has always been normal. |
GK73A "J" X2 GK73A "K" GK76A "M" XV250 **Relocated to Swansea** |
furry
1828 Posts |
Posted - 02/06/2003 : 23:52:52
Yer m8 that bottle allways needs a bit of juice in it (max 50% anti freeze, 50% water)!!! it feeds the main cycle of the cooling system.
Don't worry about markings, if you put too much in it will p iss the excess out of an overflow pipe :) |
www.gsxr400.co.uk Run by gsxr400 owners for gsxr400 owners! (Furry is Founder)
ZZR-Pilot
Malaysia
26 Posts |
Posted - 11/06/2003 : 08:08:50
There is a set of markings on the bottle, for hi and low coolant level.
To see it, you gotta peek from underneath the tail end. The markings are on the side of the bottle facing the inside. |
Ride it like you stole it..!! |
docv400
1990 Posts |
Posted - 11/06/2003 : 14:35:26
It should have coolant in it, as it feeds back into the system if the rad' cap "blows-off". There will be "upper" and "lower" levels marked on it. |
Cheers, Doc.
An Engineer is someone who can do for five bob, what any bloody fool can do for a quid! Anon. |
