 FZR400 Owners
 FZR400 1WG TURBO
Author  Topic Next Topic
noddy86
Posted - 29/03/2008 :  18:38:56  Show Profile
all views on bolting a low pressure turbo on to a 1wg 3en1 ??????
TAGGY(slow boy)'s TECHNICIAN !!!
3 OF 3 RACES STARTED AND FINISHED NOT BAD FOR 1st ATTEMPT
Evilchicken0
Nice thong !
Posted - 29/03/2008 :  18:59:36  Show Profile
waste of time and money .... fitting a 600 engine is going to cheaper and give more useful and reliable power.
Heated grips are the Devil's dildo's
garlic
Posted - 29/03/2008 :  20:22:08  Show Profile
DO IT NOW.
Some or all of the above, may or may not be true.
garlic
Posted - 29/03/2008 :  20:27:40  Show Profile
Finished?
Good.
Get started on the NO2.
noddy86
Posted - 30/03/2008 :  22:27:58  Show Profile
just wondered if it had ever been done cus the place i doin bit of work for on the side have got a couple of low pressure turbos lying around just thought might be god fun to do
garlic
Posted - 31/03/2008 :  20:41:04  Show Profile
If I had the nounce, and there was a turbo just lying around.....
It's like being in a room alone with a tea-cosy, and not trying it on as a hat.
Evilchicken0
Nice thong !
Posted - 31/03/2008 :  22:42:25  Show Profile
It isn't just a bolt on mod though is it ?
You need to lower the compression, use different carbs, pistons, exhaust, an inlet manifold and oil cooler. Hopefully the conrods and bearings will be ok
Atfer that competely remap the ecu
noddy86
Posted - 01/04/2008 :  21:16:13  Show Profile
that is very true may be just buy a hayabusa an take to big cc lmao
ste270783
Posted - 02/04/2008 :  00:05:04  Show Profile
Turn them into 2 little gas turbine engines and bolt them in the seat unit
All you need to do is conect a pipe from the compressor outlet to the turbine inlet which you use as a combustion chamber. Into that pipe you need an injector and igniter.
Then you just need an oil system for the bearings.
Edited by - ste270783 on 02/04/2008 00:16:02
martyntzr
Posted - 02/04/2008 :  09:24:58  Show Profile
noddy86 r u still looking for a set of discs for the 3en1 give me a call on 07725122011
cheers martyn
noddy86
Posted - 02/04/2008 :  15:30:43  Show Profile
think taggy managed to get some ill give him a call and find out and get back to you how much you wanting for them cudnt hurt to have a spare set if can talk him in to it.
   Topic Next Topic
