Hiya i'm just doing my fork seal's on my vfr400r nc24 just wondered how much oil i should put in each fork i've got 10w fork oil and help would be much appreciated
Correct me if I'm wrong (I'm sure somebody will) but isn't a change to 15w fork oil recommended rather than 10w??? I hope I'm right as I'm sure I used it when I changed mine!
vfr400 rg and zg right fork 340 cc left fork 345 cc vfr400 rh, rj and zh right fork 389 cc left fork 392cc
fork oil level* vfr400 rg and zg 151mm vfr400 rh,rj and zh 90mm
* oil level is measured from the top of the tube with the fork spring removed and the leg fully compressed.
vfr nc30 hannes manual has all specs for vfr 400 nc 24 at the back of it. I too would recommend 15w oil as it helped my forks stop shuddering on bumpy roads.
