  Todays Date Is: 5/17/2025 Contact Us | Home | Donations | About 400GB | Disclaimer|
 compatable break discs
rob.onions
Posted - 23/01/2008 :  22:21:17  Show Profile
I have been combing the breakers sites for a used rear disc for my 92 400SF. I have found a disc for a CB1 - does anyone one if this is the same disc and will fit??
Thanks Rob.
Posted - 23/01/2008 :  22:50:22  Show Profile
i also believe early hornet one do...
http://www.carpimoto.it/content/prod/l_EN/s_175_Disks/br_3_Honda/bi_925_CB_400_SF/sp_1/pr_3277_brake_disk_Braking_Wave_STX16D_Hornet_600_98_99_1_disk_dim_296x62_mm.htm
The part number is on the disc so you can compare it to the one on the CB1 at the breakers. Be careful of used discs as they may be warped
Also it is recommended that you change pads when changing the discs.
Posted - 24/01/2008 :  19:32:25  Show Profile
I know that most Honda discs are common. The CB-1 disc is 240mm outer diameter though, which makes it a bit bigger than the NC29. Not sure which size they went for on the SF! I have a spare rear disc. Bit worn, but straight and ready to use. Let me know if it's any use to you
rohirrim
Posted - 29/01/2008 :  21:32:46  Show Profile  Visit rohirrim's Homepage
if its any use, check out this guy from Hong Kong on eBay - http://cgi.ebay.co.uk/HONDA-REAR-BRAKE-CB400-Super-Four-Vtec-90-08-Vtec1-3_W0QQitemZ190192570313QQihZ009QQcategoryZ25632QQcmdZViewItem
i recently brought brand new discs from him and they fitted just fine to my 1994 cb400 sf. got all three discs for about £140 including
postage - that was a pretty massive saving against the prices of £350 plus for the three i was getting quoted over here! they are wavy
discs but ive done a few hundred miles on them so far and am pleased with the results so far...
